high discharge pressure on first stage of air compressor
hi to all.
What maybe the cause of an air compressor which has high discharge pressure on first stage but normal on the second stage.?
If anyone has an idea. please do comment and share your knowledge. Thank you so much
RE: high discharge pressure on first stage of air compressor
The fact that the final stage discharge is normal can be a bit misleading as it's usually determined more by what's going on downstream (eg PMV settings) than by the product of final stage suction pressure and potential compression ratio.
A.
