total mass of structure
Hi all,
if I want to get the overall mass of a modeled structure in SAP2K like a portal frame, should I add up joint masses/frame masses after completion of analysis or there's other way?
Peace
RE: total mass of structure
Add the joints vertical reactions and divide by gravity acceleration
My post above relates to dead load case
Thanks mate,
So if I want to get mass per unit length along the longitudinal length of a beam, I do as:
Area of beam (width*height)m2 * mass per unit length (kg/m3) which is defined in the material property definition = and I get the mass per length of beam
right?
