Cutoff walls in Culverts
Hello
I have a general question about cutoff walls. I understand the general idea that cutoff walls prevent piping beneath a culvert. In the specific case of a culvert used to convey a brook under a road, I see the need of installing the wall in the upstream side but I can't explain why we would need it in the downstream side. Is there a reference that explains in detail the roll of cutoff walls both upstream and downstream in a culvert? I haven't found a text or a reference saying more than "they are used to prevent piping".
Thank you so much
V.
Thank you so much
V.
RE: Cutoff walls in Culverts
HEC-14 calls for cut-off walls on both ends of the culvert.
https://www.fhwa.dot.gov/engineering/hydraulics/pu...
Downstream culvert head walls and cutoff walls are "used chiefly to protect foundations from scour in silted stream beds. A common occurrence is for erosion to start a short distance downstream from a culvert and to advance upstream, becoming more serious as it proceeds. If a head wall or cutoff extends down to firm foundation the culvert will not be endangered."
also, "Cutoff or toe walls at inlet and outlet of culverts are helpful not only in preventing scour, but also in anchoring the structure in place and in reaching firmer foundation."
Fortunately, the entire book can be read online and even downloaded (one page at a time). Here is the link:
PCA Concrete Culverts & Conduits - 1941
For convenience, I have attached the pages where the quotes given above are located.
www.SlideRuleEra.net
www.VacuumTubeEra.net
Racookpe1978 thanks for the input on seeing culverts fail because of erosion or washout from the downstream side. This will definitely help me to explain the site inspector why we need that cutoff wall there. The whole issue rose because the cutoff wall is interfering with some underground pipes and he was suggesting getting rid of the wall instead of modifying the pipes. This will help me to explain the need of keeping the walls.
Cheers!
V.
We had a contractor fail to pin the cutoff wall to the box culvert floor, and the inspector didn't catch it. After a severe storm, scour sucked the cutoff wall out from under the culvert and moved it 25 feet downstream.
