Mystical contact problem
Hello everyone!
I am doing a nonlinear simulation of a compression test of a 2D geometry with round inclusions.
Matrix is modeled as hyperelastic material, material of inclusions is chosen to be a lot stiffer then matrix. Geometry is compressed between two analytical rigid horizontal lines. Contact between rigid lines and matrix has Normal Behaviour with Hard Contact pressure-overclosure and Tangential Behaviour with friction of 0.5. Contact between inclusions and the matrix is the same, but friction is equal to 0.9. Compression is imposed by displacement of a top rigid line.
I used Plane Stress triangular elements from standart Abaqus Library (CPS3: A 3-node linear plane stress triangle.)
The task seems to be easy (The geometry and mesh is presented on the first picture), but each time I run calculation, at the first step I have always the same error following by the same warnings:
Excessive distortion at a total of 25 integration points in solid (continuum) elements
Excessive distortion at a total of 3207 integration points in solid (continuum) elements
And after:
Too many attempts made for this increment
So, I started to investigate the problem, and what I found:
1) If I insert only few inclusions in the middle of geometry - calculation runs;
2) If I add any inclusion close to the geometry border - calculation fails on the first step with the above mentioned error;
3a) If I use geometry with all inclusions, but incline the top rigid line (so the contact starts at the corner) - calculation runs
3b) If the slope of inclined rigid line is small - calculation runs, but result is extrusion of the geometry from the area between of two rigid lines (in simple words - geometry flies away).
I am using Abaqus 6.11-2/Standart
Hope someone will help,
Than you in advance
Attachements:
Problem, initial geometry: http://files.engineering.com/getfile.aspx?folder=c...
Case of a inclined line - resulting geometry: http://files.engineering.com/getfile.aspx?folder=d...
Case of 3 inclusions - resulting geometry: http://files.engineering.com/getfile.aspx?folder=2...
And after:
Than you in advance
Attachements:
RE: Mystical contact problem
Are you new to this forum? If so, please read these FAQs:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
to corus: why 3 node elements are bad and useless? Are they less stable in the meaning of possibility of distortion?
to IceBreakerSours: what do you mean under "high quality" element? Fine meshing?
to all:
1) I understand the distortion of the element, but what does the distortion of integration point means?
2) Is it normal to have small penetration of master surface into slave surface?
Additionally I tried to model "compression plates" by deformable geometry: in this case calculation runs. I thought that normally rigid object can simplify the problem, not the opposite.
http://server-ifb147.ethz.ch:2080/v6.14/books/usi/...
You should get a handle on the basics of the FEM first before jumping straight into modeling.
