Deflection Correction Factor
I am working on designs for some tunnel liners. the spec calls for using soils with 100 psf cohesion and a deflection correction factor of .6 . I figured out the cohesion issue but cannot find where to use the correction factor. Any help would be appreciated
Richard A. Cornelius, P.E.
WWW.amlinereast.com
RE: Deflection Correction Factor
I found it. It wasn't part of the load, it was part of the Arch pipe design issue.
WWW.amlinereast.com
Okay Richard . . . link?
Thanks Richard . . . interesting that the E value is to the nearest 1 psi! Have a great day!
