Mix of questions
Mix of questions
Hi all,
I have some tiny questions (that might look stupid and for a begineer) but I need you guys help.
- Is there a way to remove auto cladding once it's draw?
- How do we add a drop panel to a single concrete column or just to a few columns instead of an entire story?
- Let's say I have a core wall with coupling beams in the middle of the building to take the lateral loads (wind & Eq), how can I remove the "Programm determined Wind load overate" in the proprieties of the coupling beams that ETABS automatically assigns to those located inside the building (which is wrong because the wind applies to the perimeter of the building right?).
- When shall shell objects (floor) AND joints be boths assign a diaphragm? Shouldn't it just be floors (shell objects)?
- After I ran the analysis, I go in display "Member Force Diagram for Frames/Piers/Sprandels/Links" and when I want to show a particular combo, it seems that all of those I defined earlier aren't all shown. Is this normal? How can I make all of them appear?
- When I run the analysis, I get : " ***ERROR*** WHILE RUNNING ANALYSIS BAD FUNTION DATA" ANALYSIS INCOMPLETE
I find a solution here, but it's not working
http://danielpopp.com/2013/09/19/bad-function-data...
RE: Mix of questions
- I get this message when trying the detailling:
"Can not generate rebars, object "
Thanks if anyone could answer plz
