WAVE linked geometry in NX 8.5
I'm trying to create interpart link geometry inside the sketch (component 2 ) to create associative constraints that references the perpendicular edges of the component 1 in the Assembly.I have 3 questions.
1.If I create fillet in a sketch on component 1 , that change will not reflect on solid body component 2 with linked geometry, instead it will turn into sheet because it can't adopt change.How can I make linked associative constraints that will reflect that change?
2.In assembly if I move component 1 , component 2 is bonded with component 1, I can't separate them.
3.Is 'it possible to make wave linked geometry that will reflect changes made with synchronous modeling on a parent component.
RE: WAVE linked geometry in NX 8.5
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
When I wave link on parent component edge and project on child component in sketcher that same edge,I can't select that edge to constrain it with colinear relationship the way you did.
I guess associative constraints in questions 1 and 2 are not feasible.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Yes.
OK, I know that, but looks like something is slipping under my radar. If someone can send me an example with WAVE-linked sketch I would really appreciate that.
NX8.5.3 / TC9.1.2
HP Zbook15
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
https://docs.plm.automation.siemens.com/tdoc/nx/10...
In steps 3 and 4,you select Sketch as WAVE Link Type,and then
select the sketch along the top edge of the parent part cutout.When I try to do the same thing nothing is selectable.This is a type of example I'm looking for,and how to use sketch as WAVE Link Type.Now I'm little confused because of John's comment.
Yes, Sketch features are legitimate object types for WAVE-Linking.
That being said, without actually seeing the part/assembly or at least a video showing what it is that you're attempting to do, I'm not sure that anyone will be able to help you all that much.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
I first made sketch+extrude for the first component, and then WAVE linked face edges to be associative and position independent in the second component. After that, I made sketch using 2 edges as projected from the first component, trimmed it, and then extrude it.
So far everything is routine. But now if I cut the step in left corner of the first component, that change will not reflect on child component, it will "loose" that information and turn in to a sheet.
My idea was, is this possible to avoid by using a sketch as WAVE link type, and in general how to use sketches as WAVE link type, because as I already said I can't select anything when I try.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
