ASME B31.3 valid with tubes wall thickness??
i would like to know that does asme b31.3 wall thickness equation can be valid to calculate tubing wall thickness (as heat exchanger tubing)
thank you in advance
RE: ASME B31.3 valid with tubes wall thickness??
