grating frame in trench drain near bottom of ramp
Attached is my analysis of the perimeter steel angle for the grating over a trench drain near the bottom of an existing ramp to an underground parking garage. I believe that the upturned leg of the steel angle will be subject to lateral forces caused by the acceleration and braking of vehicles, since the project manager would like to extend the mastic traffic topping system (1" thick) to 3/8" of the back of the angle, and fill the 3/8" with a sealed joint.
Even if he were to eliminate the compressible sealed joint, and extend the mastic tight to the upturned leg of the angle, I think the mastic may be too compressible to resist much force and the steel angle will resist most of it.
Question:
Do you agree?
Question:
Do you agree?
RE: grating frame in trench drain near bottom of ramp
Richard A. Cornelius, P.E.
WWW.amlinereast.com
