Story Drift Results do not Match Joint Deflections
Could there be any reason that the story drift results would not match joint deflections? I have a case where I define a node as a story, and compare the story drift results to the same node joint deflections. The story drift does not contain a Y-drift (Y is vertical), but the joint deflections do contain Y deflections. Any ideas? I attached a screen shot for reference.
RE: Story Drift Results do not Match Joint Deflections
There is no Y direction drift because Y is your vertical axis. But, you are getting X and Z direction drift, right? And, the X and Z direction drift does match your X and Z joint deflections.
Also, what version of the program are you running? There may be an old bug that I don't remember. If I know the version I could look at the release notes for subsequent releases to see if there was anything corrected that sounds similar to what you're seeing.
Story 1 is at a 0 ft elevation. Since there is no Story 0 defined, story 0 will be assumed to also be at a 0 ft elevation! And, story drift calculations blow up (divide by zero errors). Hence the program refuses to do the calculation.
Try instead to define joint N12 (which is at -5 ft elevation) as your story 0. Then you should start to get drift results.
Apparently I was wrong about the Y drift not being reported when the Y axis is vertical. It will still be reported based on the "height" difference in the Z direction. Though I would not personally use this for anything as it is not a true drift.
