Bugwith contour levels? (version 11.0.1)
I have a model that's a simple 2D plate. I am trying to adjust the contour levels with more than the default 16.
When I change it display more levels, (say, from 16 to 24) the scale from the max to zero stays the same (8 levels) and it increases the number of levels between zero and the min stress.
Is this a known bug, or am I missing a setting/switch somewhere that allows it to scale more appropriately. The plate I am modelling has enough symmetry, that I want zero to be at the center of the scale.
RE: Bugwith contour levels? (version 11.0.1)
What version of Femap are you using and what output vector are trying to contour?
