Tank coating alternative to Siloxirane 2032, hot low pH application
Is anyone aware of a good alternative to Siloxirane 2032 that would be readily available in Europe (Italy/Germany)?
Application is atmospheric pressure, boiling (~95 to 100C) 5% sulfuric acid with other organic acids present as well (pH 1-ish). Tanks to be coated are 316LSS.
Issue in search for alternative is cost and availability.
Thanks SG
