Leaking Switchgear Roof Repair
Hello everyone,
I am currently involved in some preventive maintenance projects. I would like to get recommendations concerning how to repair leaking switchgear roofs. I am planning on using a coating of rubberized mastic cement, to cover the whole switchgear top. I'm not sure if this is common practice. There's also another option of using welding, which would require pin-pointing the point of leakage and weld there.
Thank you guys in advanced for your input.
RE: Leaking Switchgear Roof Repair
Hope this helps,
Dave
you can use polyester
LDGR I think this is similar to your idea?
Is there anyone here who has used these two combinations for roof metallic roof repair before?
Thanks.
use polyester in two layers reinforced with fiberglass. Two layers in cross will give you extra safety. Keep in mind that the preparation of the surface of the metal plate is very important for a good result.
