Plastic Deformation of Beam Elements
I am trying to model plastic deformation of a beam model in FEMap. I have set the model up in the same manner described in the examples tutorial "Plastic Deformation of Rod - Nonlinear Material" which uses rod elements. Rod elements will retain the plastic deformation, but when I change them to beam elements, the plastic deformation is not retained and the mesh behaves elastically, even though the stresses exceed the yield of the material.
I understand that beam elements will not function as 'Non Linear Elastic' but should do under 'Bi'Linear' and 'Geometric Non Linear' settings.
Has anyone run a plastic analysis of a beam model in FEMAP before, and could they explain what I doing wrong or missing ?
RE: Plastic Deformation of Beam Elements
maybe model your beam as two ROD caps and a shell web
For elasto-plastic analysis u will have to extrapolate the stress-strain curve by ramberg-osgood equation...for more detail u can visit www.femechanalysis.com
Hello!,
With the basic nonlinear module of NX NASTRAN (SOL106) for the CBEAM the only nonlinear material available is elastic-perfectly plastic. The material specified on a MATS1 Bulk Data entry should be elastic-perfectly plastic. Use of any nonlinear material other than elastic-perfectly plastic will give inaccurate results. And of course, only CBEAM element support material nonlinearities, the CBAR is not supported at all.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48004 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
Hi Guys,
Thank you for the help and suggestions. I'll try what Blas has suggested first, although I think i've tried using those material settings to no avail. Failing that, I'll try the approaches suggested by FEMACAE and rb1957.
Cheers.
Murcott
