Backwash discharge pressure
Good Morning All,
i have a concern regarding the backwash discharge from water filters, will it be under pressure or not ?
i.e. when i am going to design the drain system, shall i consider the backwash as a forced main drain or to be discharged by gravity ?
RE: Backwash discharge pressure
B.E.
You are judged not by what you know, but by what you can do.
i am not sure from water pressure after the backwash, i think there should be a pressure drop through the filter and then the discharge pressure is minimized.
TTFN
homework forum: //www.engineering.com/AskForum/aff/32.aspx
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
