new rigid elements have default color
When I create new rigid elements or CBUSh for that matter, they are displayed in the default 'white' color and not in 'red' color which I have defined. A regenerate also doesnt solve this problem. In the model info pane, i have click or element > by type > right click on rigids > color and OK. this changes the color of all new rigid elements?
any one knows how to have new rigids or any element displayed in the previously defined colors?
RE: new rigid elements have default color
When you create an element, node or geometry or whatever, it is created with the entity color. You can change it in the preferences:
File - Preferences - Color
Here you can define the enitity colors. I'm not sure what kind of entity a rigid element is, because it does not seem to take the color of the other elements..
(make sure to set the color mode in the F6 menu to entity color!)
