Moving Load Reaction
I`m using SAP-17 to build a bridge model. I don`t have the bridge modeler license, so making the bridge from scratch in sap2000.
The bridge is a steel girder bridge with concrete deck (composite system). However between the stiffeners in transverse direction there are lateral bracings. Therefore I modeled them using rigid link along the web of the girders and connected the bracing to the links.
For the vehicles I assigned lane loads and vehicle moving loads to the girders.
I get the right moments on my girders, but don`t get the right reactions from the supports which are connected to the link elements.
Can someone tell me if I`m making a wrong assumption using rigid links?
Thank you,
A
Thank you,
A
RE: Moving Load Reaction
Peace
