modal Mass participation ratio vs modal load participation ratio difference
Hello all,
Ia m conducting dynamic analysis .
I am trying to get 90 % modal mass participation ratio, however a friend of mine told me to check modal load participation ratio instead.
Actually ,I am not convinced, although the modal load reach 99% while the modal mass reach only 70&( it should be modal mass??)
So can Anyone summarize the differences between them in in etabs?
RE: modal Mass participation ratio vs modal load participation ratio difference
Since noone smarter than me replied - Let me chime in:
Did you input foundation beams/slabs in your model?
If yes - Thats your problem - Those massive concrete blocks with supoorts applied directly on them cannot be engaged with your standard 10-20 modes of vibration. Try modeling without them - only line/point supports in the base of your walls/columns.
