core and cavity module
I have tried to use the core and cavity module in catia V5R21.
I have applied shrinkage factor to a part. Then I have extracted the surfaces of core and cavity using the pulling direction command.
Later I have changed the shrinkage factor. The extracted surfaces of core and cavity did not update as per the new shrinkage.
How to maintain the link between the part and surfaces of core and cavity.
If we change the shrinkage factor, the surfaces of core and cavity should update accordingly
