Difference between Stell S275 & S235
my subcontractor asking me to change the specification of steel plates to be S275 instead of S235
is there any problem to do this modification
RE: Difference between Stell S275 & S235
difference is, amongst others:
- the yield strength
- the tensile strength
- chemical composition (with respect to welding, or CEv)
for the rest, not that much different, as they're both low property steels.
You sure bring a lot of information with you for us to answer your question.
This is for concrete insert plates
Definitely I know these differences
But my intention was: is the using of higher grade steel always better than using the least degree,
Too broad of a question. As an example, magnetic properties make the lower grade generally preferred.
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
