Asphalt Deign/Testing References
My company is frequently picking up more asphalt pavement projects. Including pavement/base coarse thickness recommendations as well as the construction materials testing side. Can any of you recommend a good textbook or any publications on the matter? I want to have a better understanding of what typically goes into the design thought process and how I can better inspect asphalt in the field. Thanks
RE: Asphalt Deign/Testing References
Despite that I have not personally reviewed for myself (as yet), I understand the following is often recommended:
Yoder, E, Principles of Pavement Design, John Wiley & Sons
Lyle
