Hex Rod
Hex Rod
I am using a Hex shaft for rollers for a convener, he shaft is 3/4 across flats, however, I can't find the tolerance for the hex coupling for the shaft. Thanks in advance for any help.
RE: Hex Rod
Are you asking about the tolerances on the part where the hex shaft fits into the conveyor rails?
If so, isn't that something you ask the conveyor manufacturer for?
Or are you asking about the tolerances on the hex shaft?
Or are you just asking for generic tolerance recommendations for a hex coupler you are making?
RE: Hex Rod
RE: Hex Rod
Whatever tolerance you want so that its bigger than the maximum dimension of the hex shaft...and small enough so the shaft doesn't rotate.
RE: Hex Rod
