Mechanical Routing - "set special discipline as default"
Hi all,
within NX 10 is there a special setting or variable to get our discipline running as default ?
Wolfgang
RE: Mechanical Routing - "set special discipline as default"
In customer defaults Routing/Part Library/Reuse Library.....you can set the default discipline you want NX Routing to start with.
Best Regards
Kapil
