Coordinate system
Coordinate system
i have a little problem. I have created a assembly and the component were created in random coordiante systems.
But now a want to have all components in the same coordinate system (CSYS of a assembly) when i open every part seperately.
That means i want that the WCS of every component is the same as WCS of assebly.
Is tha possible?
Is tha possible?
RE: Coordinate system
But I have a feeling that your concern maybe be with the Absolute Coordinate System
"Know the rules well, so you can break them effectively."
-Dalai Lama XIV
Ask them, what are they going to do about the fasteners or any Components that are used multiple times in the same Assembly? Do they realize that this means that every nut & bolt would have to carry a unique part number, or that each duplicated component would have to be created as a new part file in order to comply with that demand.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
When I've dealt with this kind of customer, fasteners were not an issue. they were just callouts on the drawing.
To make everything the same csys you could build and constrain your assembly in the desired body/machine position then wavelink the bodies into that file and make new components from those new bodies.
Probably it will be nice to have a look at the assembly first then (if possible). John has a very valid point...it is not only about fasteners but any component that has multiple copies of it in the assembly. Having multiple copies of a body in such components might be one of the way out (but looks like an overkill) but will surely impact the weight calculations.
Surely it can be a mix of both approaches (using constraints or designing components at their assembly position ) but relying solely on the components saved wrt assembly absolute CSYS approach might make things more complex.
If keeping part history of the original part is not a constraint then surely Wave linking is a way out (use Non-associative copies of the original solid in new desired components and deleting the original to avoid multiple copies of the solid/sheet).
Best Regards
Kapil
Getting back to the question at hand; you can update your geometry to the assembly coordinate system. Depending on your modeling strategy, doing so can be very easy or very difficult. First, get the position of the assembly ACS into your part. Do this by opening the assembly (it should be the display and work part), position the WCS at absolute, make the desired component part the work part and save a copy of the WCS (format -> WCS -> save). Make the component part the display part, you will find a saved WCS in this part file; it will be positioned at the assembly ACS. You will need to reposition the part construction geometry from the part ACS to this saved csys (which represents the assembly ACS). Before making any changes in the component part, I'd suggest making a backup copy so that you can refer back to it if/when things go wrong.
www.nxjournaling.com
In the end, the dummy part is in the correct position all the time. The problem is you have to go back to the original, parametric model and update it, and update the dummy solid.
If you have plenty of time, you go back to your dummy solids and make a parametric solid out of it. This would do what you need in the end. But, like I say, it depeneds if the customer cares if the model is parametric.
