Subjecting 307 (18-8-6 Cr-Ni-Mn) to extensive preheat?
Is there a detrimental effect on weld deposit of stainless steel type 307, when it is subjected to preheat of 350°C = 660°F for 1h?
We've got high carbon steel (CEv = 1) that was surfaced with 13% Mn FCAW years ago. Now the piece needs resurfacing.
This steel needs preheat of 350°C, whereas the Mn layer cannot withstand 200°C (due to carbide precipition).
As you cannot tell what parts or what depth has been resurfaced with the Mn wire, I would suggest preheating to 350°C, then a butter layer of 307, then resurfacing with hardfacing rods 350HB.
This would mean that the 307 would be subjected to high temps for quite some time (30 minutes to 1 hour, the duration of the welding operation).
Any thoughts on the use of 307 as a butter layer at these temps?
For your information, the workpiece is a switch crossing of little importance made from rail steel.
RE: Subjecting 307 (18-8-6 Cr-Ni-Mn) to extensive preheat?
You are looking to use this a weld overlay on steel, correct?
E307 weld filler is only 4%Mn, 20Cr, 9Ni.
If your filler is low C (not more than 0.03%) and you don't have a lot of dilution then the overlay should not sensitize significantly at 660F.
But I don't see why you don't directly apply the hardfacing?
google for AISI 307: you'll find most suppliers have a composition of 18 (or 19)% Cr - 8 (or 9) % Ni - about 6% Mn (At least in Europe, we do).
Yes, this is weld overlay. Problem is that the underlying surface is possibly (or highly likely, depending on the exact location) Hadfield or 13% Mn steel.
This cracks and fissures enormously when heated. Hence a ductile butter layer (elongation = more than 35%) to stop the underlying cracks from mounting upto the surface, causing more chipping/spalling.
The hardfacing rods we're currently using have 0.10%C.
It sounds like you are stuck.
I am guessing that they ignored perheat (or used a much lower temp) when they overlayed the Hadfield.
Grinding it off is your only real option, since you obviously don't want to start over on a new part.
