Flat Patterns in type design drawings.
Does anyone do this? For me I think it is a manufacturing process and should not be on a type design drawing, any thoughts on this?
I work at an Aerospace manufacturing company.
RE: Flat Patterns in type design drawings.
Per ASME Y14.5 etc. you typically detail the finished part without regard to the process, except where the process directly impacts end part function.
So you don't normally show flats of sheet metal parts on the engineering drawing.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Thank you for backing me up on this. New owners and they want to make it easier for the shop floor and add flat patterns to drawings.
My argument is that a flat pattern is not type design and only the final product should be on the drawing.
Would you happened to know what section of Y14.5 I could find that info?
"Each necessary dimension of an END PRODUCT shall be shown. No more dimensions than those necessary for complete definitions shall be given. The use of reference dimensions on a drawing should be minimized."
"The drawing should define a part without specifying manufacturing methods...."
"Dimensions and tolerances apply only at the drawing level where they are specified..."
If you lose the battle to your management, at least make all the dims on the flat pattern reference only so that it's clear the formed part dimensions are what matters.
This is where the "Dimensions and tolerances apply only at the drawing level where they are specified..." comes in.
From what I have seen the best approach seems to be (well for small companies anyway), TC drawing stack is inspection data which controlled by the design office, while flat patterns, dxf's and the like are part of the manufacturing data that forms the work instructions (the detail of which verys greatly depending on the work force skill sets). While these may be produced by design office, they should be under the control of the manufacturing group (they often are not, at small OEM's which is how the flat patterns end up in drawings).
The other point not covered is that the flat pattern is typically these days a just another step in path to creating tool paths. It's tool paths that matter with regard to revision data control.
§21.31 Type design.
The type design consists of—
(a) The drawings and specifications, and a listing of those drawings and specifications, necessary to define the configuration and the design features of the product shown to comply with the requirements of that part of this subchapter applicable to the product;
(b) Information on dimensions, materials, and processes necessary to define the structural strength of the product;
(c) The Airworthiness Limitations section of the Instructions for Continued Airworthiness as required by parts 23, 25, 26, 27, 29, 31, 33 and 35 of this subchapter, or as otherwise required by the FAA; and as specified in the applicable airworthiness criteria for special classes of aircraft defined in §21.17(b); and
(d) For primary category aircraft, if desired, a special inspection and preventive maintenance program designed to be accomplished by an appropriately rated and trained pilot-owner.
(e) Any other data necessary to allow, by comparison, the determination of the airworthiness, noise characteristics, fuel venting, and exhaust emissions (where applicable) of later products of the same type.
Like many issues with the FAA, the correct answer is "it depends". If the flat pattern is considered by the FAA ACO or designee authority that is approving the data to be required under any paragraph of this regulation or the sub-chapter(s) applicable to the article in question, it is part of the type design. If that authority does not consider the flat pattern to be required by any paragraph or sub-chapter of this regulation, the flat pattern is not required to be on the drawing, but it is also not forbidden. However, placing non-required information on a type design drawing can severely limit you with future changes if it turns out that the non-required information conflicts with a later design change.
You may want to have a conversnation with the FAA/designee who approves the design. Always be cautious, however. Asking any question directly of the FAA or designee always carries two major risks:
1. The FAA/designee may decide detailed investigation is needed into the issue and there may be unintended consequences to your design and/or extra effort required to respond.
2. If you are not the individual in your organization officially designated to be the liaison with the FAA/designee, you will at a minimum irritate the person who is the official liaison. Most organizations with a long history of working with the FAA tightly control who talks directly to them...and with good reason.
The bugaboo with this is that the construction of a sheet-metal part is very often process driven, and part of that process is making a flat pattern for that sheet-metal part, the problem gets worse when one person makes the flat ( pre bent part.) it gets inspected, and another person folds bends or otherwise processes the piece to its finished state. The more steps in the process , the more chances for error . A well meaning draughtsman may have specified what he/she thought were generous tolerances for that part, to find that accumulative errors in the flat patterning process, have used up all of those tolerances, and that now the person forming the part has a precision part on their hands with only a thousandth on an inch either way between acceptance and rejection.
rb1957 put it very eloquently : " Once you give out flat patterns you can expect all sorts of horse poop when the finished part doesn't conform ... "but I used the flat pattern", "well then, I guess the flat pattern was wrong". Accounting for sheet metal bends is not straight forward.
B.E.
You are judged not by what you know, but by what you can do.
i'm working for aerospace. not Boeing but IAI. take a look at all old Boeing projects. there's no way they don't show unfolded view.
if you're doing just a design so go with DPD. when it comes to production show everything on drawing what is needed for production starting from flat pattern and ending up with end product.
As has been noted, depending on which industry or customer standards have to be met it is often best to document the flat patterns as separate manufacturing aids, not as part of the type design (the same way QA usually creates their own bubbled drawings).
To add flat patterns to a drawing is to document a process; type design drawings should define a final, deliverable product, not the steps taken to get there.
One way I have encountered to get around this is to include such information on a separate drawing sheet which is named something other than a sheet number and does not get published (or released) with the official drawing (this was not an aerospace company).
"Know the rules well, so you can break them effectively."
-Dalai Lama XIV
Unfortunately, the first thing many people (especially management) think of when they hear the terms MBD or RDD is how much money it will save by eliminating most or all costs associated with engineering drawings. But if you think that's the case, take a look at this list of requirements for Boeing suppliers working to their MBD process.
Lastly, you might take a look at this short video tutorial that shows just how incredibly quick and easy it is using CATIA V5 to create a flat pattern from a formed sheet metal 3D part model, and then add the flat pattern to a 2D drawing.
Back in the 90s I was working for Convair, and was part of discovering a booby trap in the method you describe.
The company used a Yoder multi station roller to make Z sections for fuselage formers. They used a drawing called a "pre- form " which detailed the section to be rolled. After rolling these sections were heat treated then stretch formed to make the formers detailed on another drawing.
This system worked well for many years. Then the company decided to sell the roller and farm the job out to another company. We got the first of the " preforms" in and they were spot on to the " preform drawing". The problem was that when they were stretch formed, they were too small. After tearing our hair out for a couple of days we decided that there was no way the parts we formed before could have been made to that drawing. My supervisor and I after a discussion went over to the shop where the Yoder had been and discovered the foreman's desk. In it we found a marked up copy of the "Pre form " drawing about 20years old showing all of the dimensions increased by .1", which coincidently was about the amount the part shrunk when it was stretch formed.
The preform drawing was revised to the dimensions on the marked up print and the parts started coming out correct again. Apparently that pre form drawing had never been checked to the part, and as long as the finished parts were right nobody cared.
B.E.
Dave, if you do that , how do retain traceability?
B.E.
It seemed backward at first, and I made a hell of a fuss about it, but it worked out okay.
We were making in vitro medical devices, where the FDA surveillance is not so intense as for in vivo devices, and probably a little less intense than FAA scrutiny of aircraft, but it was still serious stuff.
Mike Halloran
Pembroke Pines, FL, USA
<rant> He didn't care. He was looking to eliminate engineers working for him by eliminating their work, plus turn this in as a bonus worthy concept to middle management. The same middle management that, on that same contract that required delivery of the drawing package, told upper management that they'd gotten a verbal agreement that no such delivery was req'd and turned back the Level III package allocation as a straight up profit to the corporate coffers.
He moved to a 'cost cutting' group that mainly looked to cut costs by choosing concepts that failed to work, so no money was saved; but a lot of money was wasted on useless concepts. The big clue was him taking only the new grads. The ones with all the best ideas, but no experience and no concept of the word "NO." They mostly were laid off after his failure, and so, finally was he. But not before a large amount of damage was done.
Same project also put weld details on weldment drawings, but absent weld fixtures or final assembly dimensions, had a lot of problems that were solved on the assembly line with grinders. Not a good feeling to watch a mounting lug get ground down to fit because the weldment was oversize. As different welders worked on the items, the factory would generate ECRs to change the weldment details to account for each welder's technique. The weld schedule was detailed - one to three passes, no order to the welds, no particular preheat, etc, for the greatest warpage variation they could muster.
</rant>
On one quick-turn design I asked the manufacturing engineer in charge if he wanted a flat pattern and was given a definitive 'We don't need your help.' Two days later I see the part on a table and another manufacturing engineer comes by. I ask what he thinks of the part and tells me the 'stupid engineer' (not realizing it was me) didn't even give them a flat pattern.
We got told " If we catch you marking up prints you will be terminated." Have you got any idea how hard it is to write an ECR without the drawing?
Then the engineers would say , " Why didn't you just mark up the print?",
There are some fights you just cannot win.
B.E.
The problem I faced was that if I accepted a slightly out-of-tolerance part in order to keep the vendor happy, I would be forced to submit a written justification explaining why this part that does not conform to my design is acceptable to use. If I did this manufacturing would typically respond with an ECR asking to change my design to allow the larger tolerance. The cost of processing an ECN would greatly anger my manager and would be immediately rejected. So I was stuck in a difficult situation with this type of problem.
That was why I included the caveat that it was not an aerospace company that used this method, where it would never fly.
-Dalai Lama XIV
I understand,
It always amazed me, that the situation I described had gone through the DC10, to the MD11, without ever being discovered.
B.E.
All that said, Type Design is the end product. The method of attaining that end product should be up to the entity building it. Yes, you need traceability, but you also need manufacturing flexibility. At one manufacturing facility (PMA house), almost all the jobs in the machine shop were routed for CNC equipment. Problem was, we didn't have enough CNC equipment to make all the parts. The machine shop supervisor (me) would look at the flow I the shop and offload jobs from the CNC machines to the manual or automatic lathes or mills just to get the parts out the door.
Since the Manufacturing Engineers wrote the routings, and the Cost Accountants used those routings to develop costs for the product, the incentive was there to manufacture the product for the lowest cost - highest profit. On paper it was nice, lower product prices - in actuality, costs went up since we didn't have capacity.
That's the main reason you don't want process documentation to be part of type design data unless that process impacts the end product features.
There is an excellent post above from debodine that is worth reading which shows the relevant section of 14 CFR 21.31.
There is no need for manufacturing engineering data about how a part is produced to be included in the Type Design under 14 CFR 21.
