My attempt at detail for base plate fixed in both directions
I am designing a pretty tall pipe rack in a high wind load zone.
The client doesnt allow any cross braces,only rigid beam-column frames with column bases fixed both ways(they already have a couple of pipe racks designed this way on the same site)
Soil conditions are very good and I can use large footings/thick slabs so foundations wont be a problem.
Basically I just wanted to double check my concept for stiffened base plate with someone neutral (Dont have much experience with weak axis bending, and I have seen some weird details on site :).
-I can make plate stress numbers work using Roark formulas
- I designed corner stiffers and their welds to transfer tension from bolts directly to column flange so I dont have to specify thick full penetration welds on botom of column flanges (is this valid to assume?)
Thx for the input!
Thx for the input!
RE: My attempt at detail for base plate fixed in both directions
If it were me, I'd try to use anchor bolt chairs and prestressed anchor rods to improve connection bending stiffness and fatigue resistance. Perhaps the scale of this frame doesn't justify such measures however.
Dave
Thaidavid
