How to calculate the pump surge pressure?
Dear All,
I am right now looking for some pumps attached in parallel to a header I want to calculate the surge in startup of pump to cater the hammering in the header
RE: How to calculate the pump surge pressure?
Is this anexkating Pdroblem or anew set up?
The data loggers are not expensive:
http://www.wateronline.com/doc/pressure-transient-...
You might also investigate soft start systems for the pumps.
Would suggest more detail is required for meaningful answers.
