Strain Gage for Settlement Monitoring
I am working on a project that has a long history (15+ years) of serviceability failures (i.e. cracking drywall, sticking doors etc.). The building in question is a simple single story wood-framed building on a continuous wall footing system. Post-installed jacking piles were installed about 15 years ago to attempt to mitigate the building movement. It appears that either this method didn't do what was intended or there is something else going on with the building that is unrelated to the foundation. Due to the long history of issues and employee turnover for the client there is not sufficient information documenting when/where all the issues have occurred. I am trying to establish if movement of the building has stopped or not so I can proceed with determining a fix, or can state with confidence that the movement has stopped.
Outside of basic monitoring (i.e. measuring cracking, grade shots, plumb checks) are there any more precise monitoring options to determine if movement has ceased? I was thinking strain gages placed across cracks in drywall, along with more global checks to monitor the issue. Perhaps I am overthinking this.
Any guidance would be greatly appreciated.
RE: Strain Gage for Settlement Monitoring
With your name implying the badger state (Wisconsin), where is it? Some areas have vicious soil problems related to moisture changes mainly.
