Accelerometer as a vibraton detector
thread384-378105: Are smartphone accelerometers useful for vibration characterization?
Can i use the Accelerometer of my phone to detect the small vibrations? if yes, then how? What application should i use? Is there any need of extra hardware?
RE: Accelerometer as a vibraton detector
How fast? A cellphone's acceleromter is limited to maybe 100 Hz.
There are zillions of apps that can read the accels and log the data, at least for Android.
You would also need some rigid means of coupling the vibration to the phone.
Offhand, it would seem to me that an Arduino based solution might be better.
https://www.sparkfun.com/products/10937
or
https://www.sparkfun.com/products/11055 which has a Atmega 328 processor included.
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
Vibration
By Diffraction Limited Design LLC
$4.99
Pasted from <https://itunes.apple.com/us/app/vibration/id301097...;
VR Mobile - Vibration Testing
By Vibration Research Corporation
Pasted from <https://itunes.apple.com/us/app/vr-mobile-vibratio...;
Good Luck
Walt
