Auto-Meshing Perpindicular Shell Elements
Is there a way for SAP2000 to auto-mesh perpendicular shell elements? For example, you are modeling a shear wall on a mat foundation. Set the shear wall to auto mesh, and have each auto meshed node connect to the mat?
RE: Auto-Meshing Perpindicular Shell Elements
You can use Assign->Area->Generate Edge Constarints->Create Constraints Around Object Edges to make SAP automatically "weld" non-coincident joints from different objects.
