Application of genetic programming to forecast streamflow
Good day, friends. I am currently working on a research which is based on the forecasting of streamflow using genetic programming. My input variables will be rainfall, evaporation and temperature while the output variable will be the resulting streamflow.
I would be glad if I can get help on how to go about it.
Thanks in advance.
Thanks in advance.
RE: Application of genetic programming to forecast streamflow
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
Thanks.
In California, that's potentially a big issue, due to changes in ground cover from fires, which can drastically alter the runoff.
TTFN
