Just a broken image from the old IBM Dassault site circa 2001
RE: Just a broken image from the old IBM Dassault site circa 2001
I know this post is shit, but at least it beats all the threads about macro's
Kevin,
If you're so against macros, I'm curious how you add a frame and titleblock to your drawings?
@KevinDeSmet
I wasn't being a smart-aleck, I use https://archive.org/web/ from time to time too.
As far as the macro issue goes, I agree. There used to be sites out there that differentiated macros from drafting, admin, part design, surfacing, sheetmetal etc. www.3dcadforums.com/catia-forum/ and www.catiav5forum.de and www.coe.org but most forums seem to be abandoned after awhile. I might start my own dedicated to only macros in order to keep things separated...
Drew Mumaw
www.textsketcher.com
www.drewmumaw.com
Jack,
The solution to that question is that it should be in the software out-of-the-box. But it isn't because most companies using CATIA let their PLM system generate the titleblocks and frames.
