If/Then Logic to choose Thread Size ?
We're on NX9, and would like thread sizes to bump up when the rest of the part gets larger. For instance: when Outside Diameter exceeds 1000mm we need bigger fasteners.
Of course, changing the value of a clearance hole is easy using logic, but is there a way to select a different thread size?
Thanks!
RE: If/Then Logic to choose Thread Size ?
Yes there is, but this only applies to Threaded Hole features (i.e. Female threads).
When you create a Threaded Hole in addition to the numerical expressions that get created defining the sizes of the various aspects of the Threaded Hole, that are also 'string' expressions created showing the hole 'specs' such as the thread size and the thread standard. Editing the 'string' expression to a value that represents another valid thread size will cause the threaded hole to update to the new size. For example, in the attached model, if you were to edit the expression named 'Thread_Size' from '3/8-16' to say '1/4-20' or '1/2-13' the threaded hole would update. Now if you needed to replace the course thread with a fine thread, say '3/8-24' you would also have to edit the value of the 'Thread-Standard' expression from 'Inch UNC' to 'Inch UNF'. Note that you can also, by just editing the expressions, change an Imperial sized hole to a Metric hole by properly editing the values of the 'string' expressions representing the Thread Standard and the Thread Size (note that in my example the names of the 'string' expressions are my own. Normally NX assigns them normal 'p' letter expressions, I just renamed them to make it easier to find the relevant expressions for this example).
OK, so once you understand how this works, it should be very easy to set up your logic to define the appropriate contents of these two expressions that effect the size of the thread.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Totally worked.
Thanks!
