How to soft Marble cutting segment for hard material??
Hi All
My question is about Diamond Tools manufacturing, I make an segment for marble cutting with bronze and 3 wt% of Sn but still my segment not cutting good, i feel hard bond hence diamond edge polished, which element can soft segment bond.
reply will be appreciated
Shahid Mehmood
DAE Mechanical Engineer, Pakistan.
Shahid Mehmood
RE: How to soft Marble cutting segment for hard material??
1. Wet or dry cutting? If wet, is the water routed to the cutting point under pressure, or simply the blade running in a water sump?
2. Is the silicon bronze the material you are using to make the blade disk, or is it in the form of attachments (hardware, fittings, etc) to the marble that is being cut?
3. How is the diamond bonded to the saw disk? Is it a nickel bond or are you simply charging the blade with diamonds by mechanical force?
4. If a bonded blade, how thick a layer is the diamond?
5. At what surface speed is the blade turning (m/second)? (or blade diameter and RPM)
