Thickness range
Thickness range
Hi Guys
Maybe you can clarify. When using ASME IX and we are requiring CVN testing. Am i right in saying we go to B31.3 where the thickness range is T/2 to T + 1/4 inch. And not the thickness range specified in ASME IX
RE: Thickness range
RE: Thickness range
So as per ASME B31.3 para 323.3.1 below applies when Charpys required - Correct
material thickness from T/2 to T + 6 mm
RE: Thickness range
RE: Thickness range
Yes, you are correct.
Cheers,
DD
RE: Thickness range
Thanks. I just wanted a simple answer. Thanks DekDee
RE: Thickness range
Always follow the construction code requirements.
ISHACK M
