Moving Heat Source Problems
Hello all! I am currently trying to make a moving heat source on ANSYS Workbench v14.5, and since I am a newbie I am using a script I've found on a Mastery's Degree thesis regarding welding. It uses the same heat source that I want to use, called double ellipsoid.
The problem is that it's not working, so I'd like to ask your help to solve this problem. The script is shown below:
CODE --> APDL
/PREP7
ET,1,SOLID70
/SOL
CMSEL,ALL
*GET,EMAX,ELEM,,NUM,MAX
*GET,EMIN,ELEM,,NUM,MIN
ALLSEL
TIME_WELD=200
DT=1
A=0.002 !Dimention A of the ellipsoid
B=0.003 !Dimention B of the ellipsoid
C1=0.004 !Dimension C1 of the ellipsoid 1
C2=0.016 !Dimension C2 of the ellipsoid 2
TAU=-1 !Delay to position the heat source on the plate
FF=0.4 !Proportion Factor (front)
FR=1.6 !Proportion Factor (rear)
Q=2400 !Energy
VEL=0.0025 !Welding velocity
NPT=TIME_WELD/DT
*DO,ii,1,NPT,1
WTIME=(ii/2)
TIME,WTIME
HCENTER=VEL*WTIME
*DO,jj,EMIN,EMAX,1
X=CENTRZ(jj)
y=CENTRZ(jj)
Z=CENTRZ(jj)
CSI=Z+VEL*(TAU-WTIME) !Moving coordinate system equation, making the global equation a function of [x,y,z,t].
! The Heat source must move only through the Z coordinate.
*IF,Z,GT,HCENTER,THEN
!It should make a verification to determine the ellipsoid on the front of the heat source and the other ellipsoid
!on the rear of the heat source
C=C1
F=FF
*ELSE
C=C2
F=FR
*ENDIF
PART1=(6*(3**0.5)*F*Q)/(A*B*C*3.14*(3.14**0.5))
PART2=(exp(-3*(X/A)**2))*(exp(-3*(Y/B)**2))*(exp(-3*((CSI/C)**2)))
QF=PART1*PART2 !Global equation, a function of [x,y,z,t]
BFE,ii,HGEN,,QF
*ENDDO
SOLVE
*ENDDO
TIME,100
DELTIM,0.5,0.01,0.5,1
I am the one who commented those lines based on what I've figured out so far. It sometimes plots random heat spots on the plate, and some other times it plots a weird heat source located nearly [-0.005,0,0] (meters). The temperature grows near that spot ([-0.005,0,0]) as some random points of heat. So far I couldn't makea moving heat source. Can someone help me on this? It would be really appreciated! Thanks in advance!
