Rebar Cover and Grout
I have question needing quick response regarding rebar cover. We need to cut down the top of a foundation for they placed rebar and top of concrete higher than specified. This will involve cutting into vertical dowels and removing 1 or 2 ties. If the concrete is cut down and 2" of baseplate grout is placed, can this 2" count as rebar cover? (cementitious grout will be used).
Thanks in advance!
Thanks in advance!
RE: Rebar Cover and Grout
Larry from Lehigh White Cement Company
