macro applying command to selection (several elements)
hi guys. trying to figure out how to apply a command to several selected elements. i can select several elements without any problem but i'm having issues how then to apply a command to my selection.
do you have any examples of how to do that?
any help will be appreciated.
cheers.
RE: macro applying command to selection (several elements)
with a dialog box. for example.
message box please select contours for disassembling.
now i want to apply disassemble or whatever command to all selected contours.
I believe with disassemble you need to use Catia.StartCommand "Disassemble"
The problem is this only launches the disassemble window but doesn't click the buttons for you...you need user interaction to click the option you want and the ok button...hence the macro will not wait for you to do that.
In theory you would want to loop through all selected objects and perform some task. You may need to add the selected items to collection because the operation you want to perform will not work with multiple objects in the selection.
'Add selected objects to collection
Dim cObjects as Collection
For i = 1 to oSelection.Count
cObjects.Add oSelection.item(i).value
Next
oSelection.Clear
'do something to all the objects
For i = 1 to cObjects.count
'add one of the objects to the selection
oSelection.Add cObjects.item(i)
'Do something
oSelection.Clear
Next
Again, this is a bad example because the macro will not wait for you to pick the buttons on the Disassemble window...but hopefully you get the idea
thanks a lot for the idea. i was thinking about something similar.
i get the error at cObject. object required
CATVBS
Sub CATMain()
Dim Seleton
Dim cObject
Dim USelLB
Dim InputObject(0)
Dim oStatus
'Dim oSel As Selection
'Dim oSelItem As Object
Set Selection = CATIA.ActiveDocument.Selection
'Set cObject = CreateObject
InputObject(0) = "AnyObject"'selection filter forces user to select specific objects, AnyObject allows selection of any object
'Set Selection = CATIA.ActiveDocument.Selection
'Set USelLB = USel
Msgbox "PRESS OK AND SELECT ELEMENTS"
Selection.Clear'You should clear the selection before making a selection
oStatus = Selection.SelectElement3(InputObject, "Select objects to list names", True,CATMultiSelTriggWhenUserValidatesSelection, False)
Dim cObjects
Set cObject = Selection
For i = 1 to Selection.Count
cObjects.Add Selection.item(i).value
Next
Selection.Clear
'Do something
Selection.Clear
Next
End Sub
  • You Dim cObject 2 times, I would stick with oSel or oSelection as your selection variable...using cObjects is confusing because the c notation made me think it was a collection.
  • Make sure you clean your codes up, there was a lot of unused variables that made it confusing
  • Collections are only available in VBA, CATScript/catvbs you would need to use an array to collect objects. I think the code below will work :).
  • You may want to narrow your selection filter to make sure they are picking the type of object you want them to pick. With AnyObject they could pick a part...but you can't disassemble a part.
  • As I mentioned before, using disassemble is not a good example for looping so I changed the code to throw a messagebox.
CODE --> catvbs
Sub CATMain()
Dim oSelecton
Dim oSelectionLB
Dim oStatus
Dim aSelectionFilter(0)
Dim aCollect()
Dim sMessage 'as string
Set oSelection = CATIA.ActiveDocument.Selection
Set oSelectionLB = oSelection
aSelectionFilter(0) = "BiDim"'selection filter forces user to select specific objects, BiDim lets you pick a surface or face
'You don't want them to pick a face though so give some instructions in your message box
sMessage = "Select a surface feature from the specification tree"
Selection.Clear 'You should clear the selection before making a selection
Msgbox "1. Press OK" & vbCrLf & "2. " & sMessage
oStatus = Selection.SelectElement3(aSelectionFilter, sMessage, True,CATMultiSelTriggWhenUserValidatesSelection, False)
'You really dont need ostatus, it is for checking if the selection was Normal
'You can just use: Selection.SelectElement3 aSelectionFilter, sMessage, True,CATMultiSelTriggWhenUserValidatesSelection, False
If oSelection.Count = 0 then
msgbox "Nothing selected, Macro canceled"
exit sub
End if 'Add selected objects to collection Redim aCollect(oSelection.Count - 1) 'You have to -1 because Arrays start at 0 but selections start at 1 For i = 1 to oSelection.Count
aCollect(i-1) = oSelection.item(i).Value
Next oSelection.Clear 'Do something to each collected object, This area may need some changes to work For i = 0 to uBound(aCollect)
oSelection.Add aCollect(i).value 'May need to take out .value...cant remember
msgbox oSelection.Value.Name
oSelection.clear
Next End Sub
well with a following code a can select several curves and disassemble them. but i need each curve in a separate geo set. like curve 23 in geo set 1 and parallel in geo set 2
CODE --> vba
Sub CATMain()
Dim Document, Part, SELECTION, Status, sSel
Dim InputObjectType(0)
Set Document = CATIA.ActiveDocument
Set Part = Document.Part
Set SELECTION = Document.SELECTION
SELECTION.Clear
InputObjectType(0) = "AnyObject": iMsg = "Select curves..."
MsgBox "PRESS OK AND SELECT CURVES"
Status = SELECTION.SelectElement3(InputObjectType, iMsg, _
False, CATMultiSelTriggWhenUserValidatesSelection, True)
If ((Status = "Cancel") Or (Status = "Undo") Or (Status = "Redo")) Then Exit Sub
CrCount = SELECTION.Count
For i = 1 To CrCount
'Set SelectedElement = SELECTION.Item(i)
'Set myCurve = SelectedElement.Value
Dim hybridShapeFactory As Factory
Set hybridShapeFactory = Part.hybridShapeFactory
CATIA.StartCommand "Disassemble"
SELECTION.Clear
Next i
End Sub
Workaround, in CATScript.
CODE --> CATScript
Language="VBSCRIPT"
Sub CATMain()
MsgBox " Select curve (FROM TREE) to disassemble, it will be created in Disassembled Curve Geo Set. Only 50 loops, modify according to your needs or hit ESC to exit "
Set oDoc = CATIA.ActiveDocument
Set oPart = oDoc.Part
Set oHSF = oPart.HybridShapeFactory
Set oSel = oDoc.Selection
Dim Filt(0)
Filt(0) = "AnyObject"
For i = 1 To 50
oSel.Clear
Ret = oSel.SelectElement2(Filt, "Select curve (FROM TREE) to disassemble", True)
	If (Ret = "Cancel") Then
	Exit Sub
	Else
Set oHB = oPart.HybridBodies.Add()
oHB.Name = "Disassembled Curve " & i
oSel.Search "Topology.CGMEdge,sel"
For n = 1 To oSel.Count
Set mySel = oSel.Item(n)
Set oCrvRef = mySel.Reference
miLongitud = Len(mySel.Reference.Name)
strTmp = Right(mySel.Reference.Name, miLongitud - 21)
miLongitud = Len(strTmp)
Texto= Left(strTmp, miLongitud - 1)
Set oRefCurva = oPart.CreateReferenceFromBRepName(Texto, mySel.Value)
Set oCurva = oHSF.AddNewCurveDatum(oRefCurva )
oCurva.Compute
oHB.AppendHybridShape (oCurva)
Next
End If
Next
End Sub
Fernando
https://picasaweb.google.com/102257836106335725208 - Romania
https://picasaweb.google.com/103462806772634246699... - EU
thanks a lot Ferdo. any ideas how to do that with select element3? i want to select several curves and then run geo sets and disassembling creation.
yea you are right it's the same number of clicks. but it looks like interruption. select wait for creation select again and so on.
tried to edit the code a little bit. i can select several curves using select element3 but all curves after disassembling are located in the same geo set. cant figure out how to tell them to go different geo sets.
sorry for too much questions. guys i'm from Israel and we don't have any scripts training in here. the only way is to go abroad. 4 days course like 3 grands not including flight and a hotel pc.
Awesome code Ferdo! You get a star.
Thank you lardman.
@JeniaL: There is also no scripting training in my country....I've learned all this stuff on hard way, reading, doing, trying, testing...lot of time lost reading again...and most important learning from advice coming from users like Eric, catiajim, littlechulu, gvi and few others...and I'm still learning from peoples which became more active on the forum in last period.
Funny thing is now I have to do the same thing in Enovia with v6...so you can imagine how I feel... nosmiley
Fernando
oh yea i can imagine. switch back to v5
