Precast concrete beam column connection
In past literature it keeps on mentioning about exterior and interior precast beam-column connections. Can anyone please explain the difference of these two. Also can anyone attach most commonly used precast column-beam connection detailed drawings if possible. Thank you
RE: Precast concrete beam column connection
On a given frame line, I imagine that the exterior joints are the two at the ends of the framing line and the interior joints are the rest. What a common detail looks like depends on your marketplace and you application. The PCI design manual is a good place to start.
