labview project 2011
I've a lab view project working under lab view 2011. the license of the lab view software has expired then i've downloaded a trial lab view 2001 version from web and it has installed successfully but the project stop to work !.Also, the ladder diagram of the project can't be browsed !.
by the way, during installation of lab view, the attached message is appear and i've no idea about !, hence, i choose (decline support) to complete installation.
Please advice me about this message and if this might cause the problem ?!..
RE: labview project 2011
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
Don't you think that the trial version might not support full function?
Have IT update your license and be done with it.
Dan - Owner
http://www.Hi-TecDesigns.com
You might find some other options in forum244: UL (underwriter laboratories) Code Issues (National Instruments:LabVIEW).
Z
TTFN
Z
