Earthquake loads
Earthquake loads
may I know should a frame be designed for total earthquake load that is acting at each floor? if no, how should the total earthquake load be allocated to each frame? Thanks for responding
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Earthquake loads
Mike McCann, PE, SE (WA)
No, not unless there's is only one frame and somehow no eccentricity in the applied seismic load.
Based on a structural analysis considering the relative stiffnesses if the frames and the diaphragms. This document explains the basics: Link.
Cheers
The document referred by KootK is part of handouts for Earthquake Engineering Course (ENGC 6336), taught by Samir Shihada, professor in structural engineering at the department of civil engineering in the Islamic University of Gaza.
Here is the Link to the download page, in case you or others are interested in downloading related documents, too.
A good structural engineer is often a blessing for others.
