direct shear box test
in the direct shear box test, there are two steel plates (top and bottom) that sandwich the sample. one side of the steel plate is smooth but the other side has a undulated profile that is in contact with the soil sample. I watch a video which say that when placing the steel plate, the direction of the undulated profile is at right angle to the direction of shearing.
Can any one know what is the reason?
RE: direct shear box test
My understanding is that in the direct shear box the failure surface is already pre-determined at the interface between the top and bottom half, the undulated profile in the steel plate is to facilitate drainage during shearing, so it should not matter how it is placed.
