Site Class B versus C
I have a project in Chattanooga TN that is classified as a Site Class C by shear wave velocity test to 2300 fps. However, by putting in a basement at -12'-0" below grade and updating the shear wave velocity test to discount the top 12' the shear wave velocity increases to 2600 fps and is then a Site Class B. The design team would like to utilize the site class B to eliminate various requirements necessary if it is a site class C. However they do not want a basement.
Therefore, if I design my structure starting from 12' below grade (drilled piers to bedrock) is it reasonable to use the lower base shear afforded by a higher site class B? I also would eliminate seismic ties as well.
RE: Site Class B versus C
I don't have code commentary in front of me, but I'm pretty sure site classification is based on the top 30m of soil, not the 30m below the foundation level.
With that said, if you can reasonably make a case, then go for it. Otherwise, I'd follow the code. If the owners don't understand or care, you don't really want to be working for them anyway. I know that's easy to say from a distance, but I think it's true.
