work remotely nx/tc
work remotely nx/tc
Hi Joe,
Some questions here about how best to work remotely.
User A wants to:
I see the check-out->'Export Dataset On Check-Out'.
This works for one file in the temp folder, but not sure how best to get all others. Don't want to check-out all others.
From NX,
User A wants to:
- Download an entire assy to hdd,
- One of those files being checked-out to him
- and let the other files be worked on by other engineers.
- work remotely on his file,
- then check it in to server when back home/slow vpn at hotel overnight.
- re-download updates from other engineers, not checked out.
From NX,
- I can export an assembly outside teamcenter to c:\temp,
- Then check-out and 'export dataset on checkout' the one file i need from TC.
- However, If the file I need to work on is an assembly, then the links to sub-components are all hosed.
