Label Chamfer
Label Chamfer
Label Chamfer
Hello Everyone,
I am trying to use label chamfer in Siemens NX 9.0, The part i am using is imported from CATIA and before doing label chamfer I have optimized the whole part but when i am applying the label chamfer feature it shows and alert "The face doesn't match the definition of a chamfer and cannot be labeled" but the thing is that I have used chamfer command to create that chamfer and then i have optimized the whole part but when it comes to label chamfer it shows that error again. can anyone suggest me the possible solution/the reason?
Thank you
RE: Label Chamfer
Is it a 45 degree chamfer ?
RE: Label Chamfer
Is the edge of perpendicular surfaces?
"Know the rules well, so you can break them effectively."
-Dalai Lama XIV
RE: Label Chamfer
Yes It is a 45 degree chamfer, I have uploaded the .jpeg file may be that can help a little to understand
RE: Label Chamfer
I don't know, it might just be an optical illusion, but that does not look like a 45° Chamfer.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
RE: Label Chamfer
can you suggest me the best way to find out if the surface is planer or not, or I would say any command to analysis the planer surface ?
RE: Label Chamfer
Information -> object... pick the face, the information window will open with the details. Somewhere in the list it will report the "surface type".
www.nxjournaling.com
RE: Label Chamfer
Thank you Mr. Cowski, Its not a planer surface. thank you everyone else too for your help.
