Need to adhere copper sheet to wood covered with cured epoxy. How?
I am making a kitchen counter top that is plywood underneath and I want to apply a sheet of copper to the top. Tried it using "System 3" 2 part epoxy and the bond was ok to the wood sustrate but it let loose from the copper. I need to try another approach. Now I have the wood covered with a nice bed of cured epoxy and I want to bond my copper to it. Can anyone suggest a solution? Thanks, Trees12345.
RE: Need to adhere copper sheet to wood covered with cured epoxy. How?
Good luck,
John Schrock
www.glubie.com
