Minimum Lateral Force to restrain a concrete column
I have a case where the reinforcement bars in a column do not protrude into the slab above, bars were fixed short. The column is cast.
No, If a design the column as pinned at the top, I still need to provide minimum restraint so that column top cannot move laterally and remains fixed to slab.
I intend to dowel bars into the top of the column that will protrude into slab. Now, I want to know what the minimum shear is I must design this dowel connection for. In this case, a 650 x 450 column with an axial load of 3300kN.
I know for steel members there is a percentage of axial load used as minimum force needed to restrain the steel member, but I cannot find a similar prescribed allowance for concrete columns.
RE: Minimum Lateral Force to restrain a concrete column
