Save As PDF specific sheet only
Is there a way to export to PDF only specific sheet?
I manage to filter those sheets by their name, but don't know the proper way to export them, and I need to create new PDF file for every sheet that is exported.
RE: Save As PDF specific sheet only
when i google "catia save drawing pdf" i find this
Eric N.
I was thinking of solving this with macro which exports only sheets containing specific string in currentSheet.item(i).name
You can manage export sheets in PDF with PDF printer (eg with PDF CREATOR ) , when printing you can select the current sheet or all documents.
Check out if it is your requirement.Goto tools..options...compatibility...graphic formats....export sheets....check out save as single vectorial file. All the best.
