Dimension styles
Dimension styles
Dimension styles
In catia V5 R21 can we create multiple dimension styles in single file, like we can create in Auto CAD.
se1430
RE: Dimension styles
CATIA V5 has two levels of describing dimension appearance; a Standard and a Numerical Display Description. You can define as many of these as you want, as long as you have admin privileges.
The drafting Standard defines general drawing & dimensioning rules based on ASME, ANSI, ISO, DIN, JSI, etc. standards.
The dimension Description defines what the dimension actually looks like; inch, millimeter, feet-inch, MAX/MIN, smaller text size for tolerances, etc.
I have no idea how AutoCAD works.
you cannot define multiple styles in a single file.
yes you can. you can define as much styles as you want. you can add additional styles in a standard file
